(DP 18) Update of the Geometry component in Coarser mesh for Design Point 18 failed: Ya se agregó un
March 7, 2022 at 12:11 am
gerardsoldevilla99
SubscriberERROR in Response Surface Optimization: "(DP 18) Update of the Geometry component in Coarser mesh for Design Point 18 failed: Ya se agregó un elemento con la misma clave."
Hi everybody. I ask for help or any idea on how to solve this problem. I am running a simulation of a certain geometry, which is not important for understanding the problem. The simulation is taking place with CFX. I ran the simulation with no problems. Then I needed to create an optimization experiment, so I added a response Surface Optimization component to the project schematic.
March 7, 2022 at 2:29 pmRK
Ansys EmployeeHello,
Seems like the meshing is failing at a particular DP with change in geometry. Can you please make sure the mesh settings will be appropriate for all geometry changes that will take place? For this particular case, you can do a test - Take the DP geometry which is failing, make sure mesh is good and solve it individually. This will give you a better idea of the mesh settings.
March 9, 2022 at 4:13 pmgerardsoldevilla99
SubscriberHi. The mesh setting seems to be right, in fact, this project is based on another before, I copied and then modified it. Actually, I have recreated it from the beginning, I created the same project and now it is working. Tank for your help any case
2524
2066
1279
1096
459
