DP for FLUENT in Workbench not updating
    • desouzadacosta
      Hi All,
      I want to execute a DP study using fluent and workbench, some parameters are properties(in a previous discussion the issue was solved).
      I assembled the DP table but it was not updating any of the DP.
      I am adding the pics of the issue.
      Any expert advice would be very welcome, as I believe this kind of parametric runs is useful for all Fluent users.
    • RK
      In the workbench window under the Project tab, when you click on the "Parameter Set" (which is shown in the first picture you have inserted) you will get a tab named "Properties of Schematic: Parameter Set". Can you change the value of  "Retained Design Point" to "Update Full Project" and try again.
    • desouzadacosta
      Thanks for the reply.
      I just tried that but the problem persist.
    • RK
      What is the error message you getting?
    • desouzadacosta
      It just does not say too much :
      (DP 0) Update fo Solution Component in FluidFlow (Fluent) for Design Point 0 failed: Update Solution Failed
      By the way I using some properties as input parameters, following similar Fluent TUI commands as below :
       (after adding nitrogen fluid in materials):
      /define/parameters/input-parameters/advance> use-in
      Select type:> scheme-proc
      Name of parameter ["parameter-3"] rho-p
      rho-p value [0] 0.06
      Enter the name/body of apply-function [] (lambda (value) (ti-menu-load-string (format #f "/define/materials/change-create nitrogen nitrogen yes boussinesq ~g no no no no no no" value)))
      It is running fine inside Fluent, but not in workbench.
    • DrAmine
      Double check the documentation regarding scheme based input parameter.
    • DrAmine
      you need to do that only once and not every time.
    • DrAmine
      And the parameters to be then provided vis startup scheme if procedure is used.
    • desouzadacosta
      Hi Amine,
      Thanks for the output. I only found section 7.1.8.2.3 in the Fluent Users Guide.
      I am trying to understand, what you said : "do that only once and not every time" and
      "provided vis startup scheme". Can you give some sample lines of code(or section numbers) to acquire that ?
      Best, Alex
Viewing 8 reply threads
