DPM and Dynamic Mesh in two opposite directions
    • mreza65
      I am working on a channel with two membranes at the bottom. When the fluid is water, I can run my simulation in each configuration. However, when membrane movement is out of phase (i.e. : one membrane goes up and the other goes down) I cannot run my simulation. After the first time step, some errors pop up like below:
      Advancing DPM injections ....
      number tracked = 100, escaped = 0, aborted = 0, trapped = 0, evaporated = 0, incomplete = 0, incomplete_parallel = 0
      iter continuity x-velocity y-velocity energy time/iter
      20 9.1819e-04 1.9813e-05 2.4465e-05 8.0521e-17 0:00:05 20
      Stabilizing x-momentum to enhance linear solver robustness.
      Stabilizing x-momentum using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: x-momentum Stabilizing y-momentum to enhance linear solver robustness.
      Stabilizing y-momentum using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: y-momentum Stabilizing pressure correction to enhance linear solver robustness.
      Stabilizing pressure correction using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: pressure correction Stabilizing temperature to enhance linear solver robustness.
      Stabilizing temperature using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature
      Error at host: floating point exception
      Error at Node 0: floating point exception
      Error at Node 4: floating point exception
      Error at Node 3: floating point exception
      Error at Node 5: floating point exception
      Error at Node 2: floating point exception
      Error at Node 6: floating point exception
      Error at Node 1: floating point exception
      Error: floating point exception
      Error Object: #f
      I tried different mesh configurations, but I could not fix it up.
      I highly appreciate it if I know your feedback.
      regards
Viewing 0 reply threads
