DPM Concentration on Auto Range or Clip to Range in Contours in Fluent
    • Pluto922
      Look at the display range, if you set the first image range to 0 to 1e-2 I suspect you'll see something like the third image. n
    • Pluto922
      Figure 1. Auto Range is selected of the DPM conc.nFigure 2. Clip to Range is selected and Min 0 to Max 0.01 of the DPM conc.nOh, Rob, you are right. nBut there are some tiny gap in figure2. And what is worng in figure1, why the DPM conc not displayed ?n
      The holes in Fig 2 are regions where you've clipped the display range: if you turn off clip to range you'll see those areas in red: they're regions with a value higher than 1e-2 kg/m3. nFig 1 is displaying the concentration, it's just the bulk of your region has a concentration under 1.7e-2 kg/m3 with the revised scale in Fig 2 you can see it.
Viewing 3 reply threads
