July 30, 2019 at 2:07 pm
Ansan
SubscriberI am using DPM surface injection model with coal as a fuel. It is carried by CO2. My model has converging inlet duct which ends at the burner main body. But when I view my DPM concentration contour I see the lower concentration region inside the inlet duct. What could be the problem regarding the variation in the dpm concentration inside the inlet?
Thank You
July 30, 2019 at 2:56 pm
Ansys EmployeePlease post some images along with a screen shot of the injection panel.
July 30, 2019 at 3:05 pm
July 30, 2019 at 3:07 pm
Ansan
SubscriberIf we observe properly we can see there are some regions with lower concentration? What might be the reason?
July 31, 2019 at 10:25 am
Ansys EmployeeCan you also plot particle trajectories?
August 1, 2019 at 5:31 pm
August 2, 2019 at 11:21 am
Ansys EmployeePlease can you plot the particle tracks on the same view as the source term contour?
August 4, 2019 at 5:08 pm
Ansan
SubscriberIn the rosin rammler distribution, surface injection, I entered the mass flow rate of particle, but in the velocity magnitude option should I enter the velocity of particle or should I enter the velocity of a coal carrier which has different mass flow rate and hence different velocity?
August 5, 2019 at 5:05 am
DrAmine
Ansys EmployeeTrajectories?
2524
2066
1279
1096
457
