December 4, 2019 at 6:56 am
Abdelrahman92
SubscriberHello
I am trying to study a system looks like this: (suspension of cylindrical particles in stagnant fluid, then I spherical particles are injected to study the settling through the suspension). So my question:
Is it possible to achieve that using DPM, my plan is to:
(1) Create one injection of cylindrical particles, and simulate the suspension by Unsteady tracking, then
(2) Create second injection of spherical particles and study its settling using previously initialized suspension fluid (fluid + cylindrical particle)
The two injections have different properties (type, density)
Is DPM suitable for that or I need to go for Eulerian models ?
Thanks
December 4, 2019 at 11:12 am
DrAmine
Ansys EmployeeFluent does account for spherical particles. If the shape is something different you might need to use another drag law and some modifications. -
December 4, 2019 at 11:14 am
DrAmine
Ansys EmployeeIdeal points of mass that is the basis. If volume blockage is important you might either try resolving particles and using MPM or rely on Dem software -
December 5, 2019 at 10:49 am
Abdelrahman92
SubscriberOk. I will try MPM. but is it possible to simulate suspensions in MPM ?
December 5, 2019 at 4:30 pm
DrAmine
Ansys EmployeeMpM is limited to few number of particles not thousands. Mpm is resolving spherical particles so not idea too. That is why either adjusting dpm laws or use DEM software. -
December 5, 2019 at 4:38 pm
Abdelrahman92
SubscriberThanks for your advice
But I am still wondering if I used DPM with two injections. Does the two injection interact with each other. I mean if I inject the first type of particles (cylindrical) and initialized the flow field then inject the spherical particles, Does the model account for the viscous drag reduction because if the first injection? Or the spherical particles will simply solved for the fluid domain ??
Regards -
December 5, 2019 at 4:41 pm
DrAmine
Ansys EmployeeIf two way coupling yes as the first influences the flow field so that the second injection sees that disturbed flow field. -
December 5, 2019 at 4:51 pm
Abdelrahman92
SubscriberGood
Thanks. I will try it and let you know.
Thanks again
5162
3275
2453
