October 19, 2023 at 6:45 am
Hital Deore
SubscriberI am working on DPM model and I am doing an unsteady simulations. So, to track particle path I have to take a sample at different time steps. I am injecting 140 parcels from inlet(tried surface as well as group injection) in one time step but when I am taking sample only 68 data entries are there when 140 parcels are being tracked. why is this the case? why it is not showing all 140 entries in sample data aslo?
Also is there any other way to track particle paths in unstedy simulation of DPM model ?
Please help me with this
Thank you
October 23, 2023 at 1:04 pm
Prashanth
Ansys EmployeeHello,
Not all the injected particles might reach the sampling plane. Since it's unsteady, when you sample them, some of the particles fate might be different.
October 25, 2023 at 5:47 am
Hital Deore
SubscriberThank you for your reply. Sometimes it is giving more data points also(more than 140) what can be the possible explaination for that..And also please explain sampling plane
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1474
