DPM skipping injection
    • shal3391
      I am trying to inject acetone parcels using a plain orifice atomizer injector into an air flow as shown.
      I keep getting the following error;
      Plain orifice atomizer injector:
      Invalid downstream density -1
      Skipping injection
      Any help would be greatly appreciated.
    • DrAmine
      Nozzles use some flow properties downstream to detect the regime. Can you show your mesh, location of the injection and add info about models? Are you able to use a supported newer version?n
    • shal3391
      The injection setup is shown below, it is a transient case using a discrete phase model with unsteady particle tracking and interaction with the gaseous phase. n
      Assuming the bottom left corner is 0,0 make the injection position 0.0001, 0.0001 as you may have missed the domain due to CAD tolerances. n
Viewing 3 reply threads
