March 11, 2023 at 7:33 pm
Afzal Iqbal
SubscriberI have build a NACA foil 0015 with a span of 8cm and conducted my flow simulation under k-omega SST model. The flow speed is 0.5m/s inside water. The boundry conditions have been set using http://ichrome.com/blogs/archives/342 and tubulent viscosity ratio to 10
But the drag graph is absurd. Giving -17N drag force at the end. Furthermore in post processing when I used function calculator to get the force in x-direction for hydrofoil (drag) I got 0.089N as my result. Can anyone point out the error/ Thanks.
March 13, 2023 at 6:56 am
DrAmine
Ansys EmployeeCan you add the screenshots behind your drag report?
March 14, 2023 at 2:25 pm
Federico Alzamora Previtali
SubscriberHow did you define the drag in your report?
3850
2629
1853
1246
600
