December 16, 2022 at 8:14 pm
erenkartal571234
SubscriberHello, i am working on a rocket. To determine the drag coefficient of the rocket, I need to set an area value as a reference value. When I select the surface area of the nose cone of the rocket, the drag force is very low (like 0.04 on a 250 cm rocket). Is this normal?
December 19, 2022 at 11:32 am
Keyur Kanade
Ansys EmployeeHello,
This is regarding your recent post on the Ansys Learning Forum. The technology raised in this topic may be restricted by the US International Traffic in Arms Regulation (ITAR), 22 CFR Parts 120-130, which controls the export and import of defense-related material and services, including export of sensitive technical data, or the US Export Administration Regulation (EAR), 15 CFR Parts 730-774, which controls dual use items. As such, we are removing your post and advice you to seek guidance using channels which comply with all applicable export-control regulations.
Thank you.
Best Regards,
Keyur
2524
2066
1279
1096
459
