September 25, 2018 at 9:30 am
September 25, 2018 at 10:00 am
paguado
Ansys EmployeeHave you checked the drag force? Is it negative or positive? The drag coefficient is obtained from this force and may take the sign. You can also use 1/2*rho*S*U_inf^2 to non-dimensionalize the drag Force and take the net value to calculate the Cd. It would be good to know if this absolute value is the same as the one you observe when you plot the Cd
September 25, 2018 at 11:39 am
DrAmine
Ansys EmployeeCheck the direction vector along which drag force and the coefficients are calculated. The vector for drag will be the direction of the flow (for lift will be perpendicular for that direction). paguado wrote what you can else try!
September 25, 2018 at 12:52 pm
mstricks
thanks sir I understand what you are saying
2616
2098
1323
1110
461
