Discovery Import
Discovery Import
Draw a spline between points in 3d
    • cbur
      it would be interesting to specify the Spaceclaim options in the documentation. Indeed the creation of SPLINE 3D is different if you activate or not the constraint based sketch. (need to click on "activate the 3d sketch"). The documentation doesn't look like it has been fully updated when it says "2020R2".
    • Subashni Ravichandran
      Hello charlie
      Thank you for pointing this out. I will notify the respective team and get this changed.
