February 28, 2022 at 1:46 pm
Wulf22
SubscriberHi everyone,
I need to draw a three cylinder solid body. Basically I want to draw the following geometry without the catalyst bed -
March 1, 2022 at 3:11 pmKarthik R
AdministratorHello:
I'm not sure if I understand your question completely. If you are trying to create 3 concentric cylinders, you should be able to use some simple pull, rotate and/or subtract operations.
If you have not already done this, please see the "SpaceClaim" course from our AICs.
Ansys SpaceClaim - Tools Tutorial - ANSYS Innovation Courses
Karthik
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2706
2146
1357
1144
462
