March 14, 2022 at 4:18 am
ericwu
SubscriberHi, everyone:
I'm drawing a coil with rectangle cross section in Maxwell, I didn't import the CAD model since I need the coil be parametered.
I used "sweep along path", while the coil "twisted" with non-regular pattern as the pictures below.
Is there any way to build a coil which each layer of sections are aligned or parallel?
Thanks!
March 15, 2022 at 2:04 pmViewing 1 reply thread- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
