October 24, 2018 at 7:32 pm
October 24, 2018 at 7:36 pm
FrankD
Ansys EmployeeIf you mean you are
able to pull a slot, can I ask if the blue component has been Activated in the Structure tree? Also, it does not look like you correctly Alt-selected an edge pointing in the Z direction. You can either activate the Direction toolguide, or Alt-select it *and if should highlight in blue*
F
October 24, 2018 at 7:46 pm
sameerfares
SubscriberThank you Frank!
i was clicking on the edge without clicking on pull direction. My mistake. i was able to do a slot earlier on the other side, but when i tried to do it on this side i didn't click on the pull direction.
sam
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
