May 15, 2022 at 11:38 pm
sam
In sketch mode, when drawing a circle within two larger circles, the surface between them is lost and seemingly no way to draw a circle and get that surface.
For example, draw 3 circles one inside of the other - large to small.
You end up with an outer ring, and an inner circle, but the middle ring has no surface. Trying to draw further circles to 'fill' the blank ring does not work, the only way to get a surface on it is to extrude one of the others first.
In this example I am trying to work on the inner ring first, I want to extrude that (the bit it has not put a surface on) to leave an outer ring, and an inner circle both flat.
How do I get it to fill/surface the bit it's excluding?
Thanks
May 16, 2022 at 4:48 am
Devendra Badgujar
Ansys EmployeeHi Sam Whitney
Let me check and get back to you.
May 16, 2022 at 7:36 am
Devendra Badgujar
Ansys Employee🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi Sam Whitney
You will have to create the middle circle again to get the surface for that and then you can extrude that keeping other surfaces flat.
Please check the attached video demonstrating the process for you. Let me know if you have any further questions on it.
Regards.
June 15, 2022 at 7:16 pm
sam
SubscriberThanks for the reply Devendra, sorry I did not see the notification until just now.
When I draw the new circle, it does not fill in the surface, no matter how many I draw (your last one) the inner ring is 'empty'.
June 17, 2022 at 2:11 pm
June 17, 2022 at 2:41 pm
sam
SubscriberDevendra Badgujar I had that originally but found it really cumbersome for me, so I turned it off and it makes SpaceClaim much easier to use as I tend to draw on and faces.
June 17, 2022 at 1:44 pm
rg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hello Devendra Badgujar
Isn't it possible by changing an option to be able to draw like in the old versions of SpaceClaim? I am attaching a video as an example.
June 17, 2022 at 2:12 pm
Devendra Badgujar
Ansys EmployeeRoberto Sam Whitney
3812
2593
1849
1244
600
