Discovery Import
Discovery Import
Drawing formats
    • rg
      Hi
      When I go to save the drawing formats  with the mechanical shot peening and save it in dxf, opening it with a 3D cad the lines lose the correspondence as in the video.
      Tried 3 cad 2d software also autocad and from the same problem.
      Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Brian Bueno
      Roberto
      Can you send an example file?
    • rg
      Hi ,
      the file is reserved I can only send it from a secure link
      Regards
    • rg
      Brian Bueno Hi Brian
      I'm waiting for the link
      • Brian Bueno
        Roberto
        I have sent the secure transfer to you.
      • Brian Bueno
        Roberto
        Does the file you sent have the same problem?  The lines already appear to be affected and different from what you show in the video.  Opening in SpaceClaim and saving to DWG does not affect the lines any further.
      • rg
         Brian Bueno Hi Brian, I sent you in the link as I see the dxf.
        I have these settings should I change something?
      • Brian Bueno
        Roberto
        These are the only differences I found.
    • rg
      Brian Bueno Hi
      even setting your settings the problem always does.
      It is not just with a file but with everyone (I am attaching a private video to make you understand better).
      Regards
    • rg
      did you see the video?
      Best Regards
Viewing 5 reply threads
