January 25, 2019 at 4:28 pm
rg
SubscriberHi is it possible to reduce the size of the letters in the section by default? By defaul they are of size 4.9 I would like them to be smaller in size How can I change the thickness of the cartouche lines? (Figure 1) Is it possible to open a new drawing pattern with only a top view and not with the 3 views? Regards
January 28, 2019 at 6:47 am
Naresh Patre
Ansys EmployeeHello Roberto
I am looking into your questions and will get back to you.
January 29, 2019 at 8:20 am
rg
SubscriberHello
I thank you, I am waiting
Regards
January 30, 2019 at 4:47 am
Naresh Patre
Ansys EmployeeHello Roberto I don't think there is any default option under SpaceClaim options to change this font size of letters in section. Thank your kind input, I would share this idea with our development team. The thickness of lines can be changed by editing the template files located under ~ANSYS Inc\v192\scdm\Library\DrawingFormats. For opening a new drawing with only top view, you can first create a template with only top view and save it as SpaceClaim template format (.scdot). Then, under SpaceClaim options, go to Support Files section and enable "Use template for new designs" option and specify the path of template file. See below image for reference. Once done, if you open any new session, you will have a drawing sheet with the top view. -
January 31, 2019 at 8:56 am
rg
SubscriberHi Naresh
thanks for everything
Regards
3804
2587
1841
1244
600
