September 2, 2019 at 3:45 pm
Custal
SubscriberIn what units/magnitude are the Z-matrix result from a driven terminal solution. I would assume they are in ohms but I cannot find anywhere that confirms this and I need to be sure.
Thanks,
Chris
September 2, 2019 at 5:37 pm
SubscriberChris, what model and what solver are you talking about?
September 3, 2019 at 8:05 am
Custal
SubscriberHFSS Driven terminal solution type
- Maxwell, HFSS or Q3D?
- Error
2706
2146
1357
1144
462
