October 28, 2017 at 12:41 am
SubscriberOne of the accessories carried around daily in this product is a water-filled plastic tube. Since it is carried around, surviving a 15 inch (38 cm) drop was one of the requirements it had to pass. A physical test demonstrated that the initial design failed the drop test.
I built a transient dynamics model of the initial design to show that the part was predicted to fail, which was some evidence that the model was valid. The water was modeled as an orthotropic solid.
Plotting the peak stress showed that the maximum stress in the model exceeded the ultimate strength of the material.
I went through many design iterations to find a few designs that were predicted to survive the drop test such as this one, which reached a peak stress of 49 MPa at 0.5 ms after impact.
Attached is a zip file containing a Microsoft Powerpoint 2013 file that has a summary report including the properties of water and some videos of the simulations.
[UPDATE: February 2020. I just learned about Hydrostatic elements and a SimuTech Group tutorial on how to use them.]
5028
3137
2377
1306
922
