TAGGED: ansys-fluent, drying, evaporation, porous-media
April 28, 2022 at 8:53 am
yfgorgulu
SubscriberHello.
I am currently working on drying fruits using Ansys Fluent. However I still need guiding on the topic. My question is when I add a solid material from the database, in cellzone or boundary conditions seems like I cannot use the solid material. Can you please explain it ? I am right now trying to make a multiphase model on the drying process.
Thanks in advance, kind regards.
April 28, 2022 at 1:40 pmKR
AdministratorHello:
Under cell zone, have you changed the type to Solid? Once you do that, you should be able to use the solid material you added.
Karthik
April 28, 2022 at 2:04 pmRob
Forum ModeratorTo add, if it's a solid then you can only model heat transfer. If you're drying something you may want to look at porous media.
Viewing 2 reply threads- The topic ‘Drying Fruit Process’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
