Drying Model Boundary Conditions
    • Theresa72
      Hello:
      I am modeling the drying  of leather using a porous zone.  The initial conditions are 400K and 0.1 m/s.  The geometry is a rectangle of 0.05 m in height and 1 m in length.  How can I set the free stream temperature or the domain temperature to 450K? I have been using 400K at the inlet and 450K in the initialization parameters that are used before the calculation is run.  Would it be correct to use the thermal boundary selected as temperature with 450K and still have adiabatic walls?  Thank you so much.
Viewing 0 reply threads
