March 8, 2021 at 8:20 am
nks_122
SubscriberHi,n I am modeling a random particle reinforced composites using Material Designer-User Defined option.nAfter completing all steps, when i am running solution, i am getting error:nDS Solver Proxy failed, failure code 516, directory: C:/Users/HareRam/AppData/Local/Temp/nAll normal simulation are running fine, but user defined option not working.nPlease suggest some solution for this.n -
March 9, 2021 at 6:41 am
1shan
Ansys Employee,nCould you have a look at this https://forum.ansys.com/discussion/9297/material-designer and see if it helps.nRegards,nIshan. n
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
