October 10, 2018 at 4:11 am
CalebOU
SubscriberMy computer has 2 Intel Xeon E5-2670 CPUs, so 16 cores, but when I am in Ansys Mechanical and go to "Solve Process Settings" under Tools, select Advanced, and specify to use anything above 8 cores, I receive an error message saying "The requested number of distributed-memory processes (>
exceeds the number of physical processors that are available (
on the machine. The use of virtual processors is not recommended. It is required that you use a maximum of 8 distributed-memory processes on this machine."
How can I get Ansys to recognize my second CPU and other 8 cores available?
October 10, 2018 at 8:16 am
Ansys EmployeeWhich software/licence are you using as the error may be due to limits in that rather than the hardware.
October 10, 2018 at 10:37 am
Aniket
Ansys EmployeeDo you have hyperthreading turned off? If that is the case, the number of threads will be the same as the number of cores. (which is recommended).
Looking at the spec sheet, if you have 2 physical Xeon E5-2670 CPUs, you should have 16 cores (with hyperthreading turned off), so if you can't use more than 8 core it might be due to the fact that you might not have enough HPC licenses to run the said run.
October 10, 2018 at 2:21 pm
SubscriberI have two physical CPUs, and without opening the box, Windows 7 shows me that when I get Properties on My Computer.
Can you confirm that you really do have two physical CPUs and not just one 8-core CPU with 2 threads per core. That will show up in Task Manager as 16 cores if Hyperthreading is On, but as Aniket says, turn that off if your main work on the computer is ANSYS models.
October 11, 2018 at 1:35 am
CalebOU
SubscriberI have license Ansys Student Teaching Introductory, it was the free student download I obtained through my school. -
October 11, 2018 at 1:40 am
CalebOU
SubscriberI do have hyperthreading turned off, in the solve.output file it confirmed one thread per core. I also was unable to use more than 32000 elements in my mesh because of my type of license, so it sounds like the student license is somewhat restrictive. -
CalebOU
SubscriberI also confirmed in BIOS that hyperthreading is off -
October 11, 2018 at 1:42 am
CalebOU
SubscriberPeteroznewman, please see above. Thank you all for your responses as well -
October 11, 2018 at 9:39 am
Ansys EmployeeI think you're out of parallel licences: from memory you get 4 with the solver and possibly 4 with the Student/Teaching version.
The Student/Teaching version is identical in capabilities to the Reseach and Commercial versions except you're limited in how many cells you can solve.
October 11, 2018 at 12:59 pm
October 12, 2018 at 2:23 pm
Ansys EmployeeOK thanks, that's changed from last time I looked, sure it was 4 or 8.
2064
1277
1088
456
