June 16, 2021 at 1:32 pm
rg
SubscriberHello When I export a file in dwg or dxf the arrows are huge. I have tried with both theiga and autodesk export. I have tried different export formats from autocad 2000 to 2007 and the problem is always the same. I have usually noticed that these errors often occur when there is an imported geometry with errors. Why is it always going to change something when exporting dxf-dwg? Best Regards -
June 17, 2021 at 6:36 am
Naresh Patre
Ansys EmployeeHello Roberto
I tried exporting the drawing sheets in dwg and dxf format and imported them back in SpaceClaim to check out the issue. I couldn't see any change in the arrow sizes. Since I don't have access to Autodesk I couldn't check it.
You mentioned that these errors often occur when there is an imported geometry with errors. What if you fix the errors? Also, If you create a simple geometry like box, then add a drawing sheet with dimension and export it in dxf or dwg format, how does the arrow size appear in Autodesk?
I am not sure if this issue is on SpaceClaim side or on Autodesk side. Are you seeing this issue with earlier versions of SpaceClaim as well or is it specific to any particular version?
June 17, 2021 at 7:03 am
rg
SubscriberHello Naresh Patre
I am writing to you in private
Best Regards
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
3744
2573
1809
1236
594
