June 11, 2020 at 8:19 am
rg
SubscriberHello
I open this service to report anomalies that many customers have complained about, I ask if there is a way to solve it.
By exporting the files to dwg the annotation and solids thicknesses are not maintained , Spaceclaim exports the file with the same thickness as all lines.
In this way the exported design is hard to read.
For example, this is not the case if you export in PDF format where the thickness of the different lines is maintained ( as in the attached photo) and the design is well understood.
The other problem that occurs during the export both in PDF and in dwg and that if you switch off the tangent lines Spaceclaim exports them anyway ( as in the attached video)
Best Regards🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
June 11, 2020 at 11:14 am
Charudatta Bandgar
SubscriberHello Robert ,
I am looking into it and will get back to you with my findings as soon as possible.
June 12, 2020 at 7:42 am
rg
SubscriberCharudatta Bandgar Hello
There is a bug in the creation of mechanical drawing boards.
When you go to save a file in dwg and there are only views with the same scale as the sheet , the (hidden) dotted lines export them correctly as in picture 1.
While when you go to save a file in dwg and there are views with different scale , the (hidden) dotted lines incorrectly export them in an incomprehensible way , are very long lines (Photo 2)
I can send myself two examples of dwg files in private
The last thing is that when I go to change the color of the views to white I do not export them with the chosen color , while with all the other colors it works. (I attach video)Export it in black or dark grey
If you need more descriptions to understand the problem and then can correct it I’m at your disposal
I look forward to your informationBest Regards
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
June 15, 2020 at 6:11 am
Charudatta Bandgar
For your third query,
I was not able to replicate the issue. I have sent you a secure transfer link, can you send your .dwg files there?
June 15, 2020 at 6:41 am
rg
SubscriberCharudatta Bandgar Yes, I can send the files in dwg, the secure transfer link has not arrived
June 15, 2020 at 7:14 am
Charudatta Bandgar
Can you please login to ANSYS's secure transfer portal and check the inbox?
June 15, 2020 at 7:28 am
rg
Now I reset the password to log in and later I enter and send you the file
Best Regards
June 15, 2020 at 8:24 am
rg
SubscriberCharudatta Bandgar Hello, I can't reset my password so I can't send you the files.
Can you reset my password or send me an email?
June 12, 2020 at 11:48 am
Charudatta Bandgar
SubscriberHello Robert,
For your first two queries, I tried replicating the issue, and they do seem to a bug. I have filed the bug report on our portal, so that the developers can look into it. For your reference the bug IDs are 298619 (tangent line bug) and 298628 (Edge thickness bug) respectively.
For your third query, I will need to investigate it further. I will get back to you with my findings, as soon as possible.
June 15, 2020 at 6:39 am
rg
SubscriberCharudatta Bandgar Thank you very much, there are a very important bug to fix
Best Regards
June 15, 2020 at 6:55 am
Charudatta Bandgar
Thanks for bringing them to our notice.
June 15, 2020 at 12:19 pm
rg
While for this mistake can you tell me something?
June 15, 2020 at 12:37 pm
Charudatta Bandgar
I am looking into it now. I will get back to you as soon as possible.
June 16, 2020 at 11:11 am
Charudatta Bandgar
this actually is a bug, thanks for bringing that to our notice.
Although I checked it with 2020 R2, the next unreleased version of Spaceclaim, with SpaceClaim export setting changed to from Tiegha to RealDWG, if the AutoCAD file is exported, this issue will not be observed. The hidden (dotted) line will not be changed regardless of having differently scaled views on the sheet, and the bug will be resolved.
June 16, 2020 at 12:31 pm
rg
well that in the next version will be correct
Best Regards
June 16, 2020 at 12:36 pm
Charudatta Bandgar
Hidden lines will be consistent with scaling in the next version.
June 16, 2020 at 12:33 pm
Charudatta Bandgar
I tried recreating the fourth query,
It also seems like either a bug or a limitation, for which I will need to further discuss it with the developers. For now, I have filed a bug report for the same, with Bug report ID 299951. Once again, thanks a lot for bringing these to our notice.
June 16, 2020 at 12:39 pm
rg
If I find others I will let you know, these I think is important BUG to correct because the export in dwg / dxf is very used
Best Regards
June 16, 2020 at 12:47 pm
Charudatta Bandgar
Yes, thanks a lot.
June 16, 2020 at 3:11 pm
rg
It would also be very nice if you could make this improvement very useful, because how it works now and almost unusable for saving dxf and printing
IMPROVEMENTS/ Idea for devlopment = traceline
Best Regards
June 19, 2020 at 2:53 pm
rg
You managed to see that the dotted lines in the exploded configuration are too thin and work and can only be viewed on video
Thanks for sharing your Idea. I will share your idea/input with the product development team about the trace line.
Regards
June 22, 2020 at 5:33 am
Charudatta Bandgar
I will look into it if there is a bug report filed, or if there any update on the same. I will get back to you regarding this.
June 22, 2020 at 6:35 am
rg
SubscriberCharudatta Bandgar Thank you very much, I hope some changes have been made since I had reported it some time ago
Best Regards
June 30, 2020 at 4:17 am
Charudatta Bandgar
I was not able to find an enhancement request filed. A new enhancement request has been filed. Enhancement request ID: 7ERAFE06292020.
Regards.
June 25, 2020 at 2:54 pm
rg
It would be very nice if as an improvement in the next versions the color of a mechanical drawing table view is not connected to the others in such a way as to be able to assign different colors.
Now it is not possible to change color only in the isometric view or in a single viewBset Regards
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Discovery AIM Mesh Error
- Natural frequencies limited to first 6 modes
3744
2573
1821
1236
594
