January 28, 2023 at 11:45 pm
ali.afrouzian
SubscriberIn displacement control quasi-static test using dynamic explicit, I put end_time = 10 with the number of steps = 10. However, as it can be seen from the picture, it gives the whole displacement at time = 1e-4 and then it jumps to end time while the displacement remains constant!
Does anyone know what's wrong here? How we can use time step and end time in dynamic explicit? -
January 30, 2023 at 1:11 pm
Ram Gopisetti
Ansys Employeehi, What is your Damping factor and CFL timestep ?, if you set these correctly and follow the guide as in and what are you trying to model in here?
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/exd_ag/ds_exd_settings_types.html?q=TYPE
it should be able to run it with no pre-termination, cheers, Ram
January 30, 2023 at 6:33 pm
ali.afrouzian
SubscriberThanks Ram for sharing the document.
I really don't want to run mass scaling at this point. Normal run would be ok.
My question is why my time step doesn't apply correctly. It looks like it applies the whole load/displacement in the first time step and then remains constant. I could not implement ramp load function as well.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5162
3275
2449
