dynamic mesh- 1dof
    • RanJ
      hi guys ,
      i'm not really familiar with ansys fluent and i want to simulate a 3D problem in which fluid move due to the force applied in the inlet (pressure)
      need help with tuto, pdf or any idea that could help me.
      thank
    • Keyur Kanade
      Please check
      you will find many threads on this community on this topic. please use search option as well.
      Keyur
    • RanJ
      hi again i have as an inlet : total pressure Boundary condition P(t) and i have creat it as a profile but in the same time i want to see the fluid movement due to the force problem (using dynamic mesh) , if i take the inlet as a wall , it can read my profile. i wonder if there is another way?
