January 11, 2023 at 9:34 pm
Santu Golder
SubscriberHi,
I am doing dynamic mesh for my simulation using UDF. What code can I use in UDF to give the distance that the moving body can travel? I want to limit the distance to be traveled between 0 to 0.25 (m). And it is an oscillation of a solid body.
Following is the equation that is applied to give the motion.
vel = 0.03*sin(1.1416*time/10.);
Santu
January 12, 2023 at 10:45 am
Prashanth
Ansys EmployeeHi
DEFINE_CG_MOTION can be used. You can also check a example case in the UDF manual.
January 12, 2023 at 5:31 pm
Santu Golder
SubscriberHi Prashanth,
Thank you for your reply. I've coded the equation as follows:
# include "udf.h"
static real velx = 0.0;
DEFINE_CG_MOTION(box,dt,vel,omega,time,dtime)
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);velx = 0.01*sin(1.1416*time/10.);
vel[1] = velx;
Message("time = %f, vel[1] = %f\n", time, vel[1]);
}But for giving the limit to move the moving box, which one should I add:
if (!Data_Valid_P())
return;or
any other loop that I need to apply.
January 13, 2023 at 12:19 pm
Prashanth
Ansys EmployeeSure, you can use if and else to limit the motion
January 17, 2023 at 6:26 pm
Santu Golder
SubscriberHi,
Can you please help me to apply the if and else statement to limit the motion? Mine is not working at all.
Regards
Santu
January 18, 2023 at 1:32 pm
Prashanth
Ansys EmployeeHi, Can you check out this dynamic mesh robotic arm tutorial that uses something similar:
January 18, 2023 at 8:51 pm
Santu Golder
SubscriberHi Prashant,
I’ve applied the following code for limiting the motion. But it did not work, My motion is sinusoidal and the length is 0 m to 0.2m. I want to limit it to 0.18 m and the box will return its initial position. It is a to and fro motion of piston in a piston chamber.
# include “udf.h”
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);velx = 0.05*sin(3.1416*time/10.);
if (time<=5)
vel[1] = velx;
else
vel[1] = velx;Message(“time = %f, vel[1] = %f\n”, time, vel[1]);
}Regards
Santu
2534
2066
1285
1104
459
