May 27, 2023 at 1:44 pm
Paolo Melidoro
SubscriberHi,
I am currently simulating blood flow in the left atrium using Fluent and have coordinates from imaging data for the position of each node on the wall at every time step. So far I have tried prescribing these coordinates (done in 2D for now) using the define_grid_motion macro however when I preview mesh motion there seems to be no change to the mesh.
//credit to Matt Fig for code
#include "udf.h"
#include "unsteady.h"
#include "dynamesh_tools.h"
DEFINE_GRID_MOTION(UFD_MOV_WALL, domain, dt, time, dtime)
Thread *tf = DT_THREAD(dt);
face_t f;
Node *v;
int n,ii;
double Vx1[500] = { node position at every time step} //done for all x and y nodesSET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
begin_f_loop(f, tf)
f_node_loop(f, tf, n)
v = F_NODE(f, tf, n);
if (NODE_POS_NEED_UPDATE(v))
for (ii=0; ii<302;ii++)
if (fabs(NODE_X(v) - Vx1[ii]) < (1e-12) && fabs(NODE_Y(v) - Vy1[ii]) < (1e-12))
NODE_X(v) = Vx1[N_TIME % 302];
NODE_Y(v) = Vy1[N_TIME % 302];
NODE_POS_UPDATED(v);
break;
end_f_loop(f,tf);
May 31, 2023 at 12:07 pm
Prashanth
Ansys EmployeeHi,
Double check the remeshing settings, smoothing methods etc.
May 31, 2023 at 1:55 pm
Paolo Melidoro
SubscriberI worked out that the problem may have been that I was using the built-in compiler when compiling the UDF which was giving me a warning about not finding visual studio compiler. I am now not using the built-in compiler however now I get this error message 'fatal error C1128: number of sections exceeded object file format limit: compile with /bigobj'. This is because I need to include a large number of arrays with all the coordinates at each time step in the UDF.
I found a solution for this here - https://social.msdn.microsoft.com/Forums/vstudio/en-US/5043c081-a317-4528-a02d-d4b6e6d21543/problem-with-bigobj-when-compiled-by-other-software?forum=msbuild however when I try to include /bigobj in the makefile_nt.udf file I cannot save it as it gives me an error message about permissions.
This thread https://www.researchgate.net/post/Is-there-any-FLUENT-UDF-macro-to-replace-the-new-mesh-in-each-time-step summarises quite thoroughly what I'm aiming to do with prescribing the node position at each time step,
7626
4456
2955
1427
1322
