September 3, 2018 at 3:33 pm
aCVP
SubscriberHi all,
I have a 10 frame dynamic (4D) cardiac CT of a beating heart.
I have segmented each frame and created a separate mesh. Is it possible to use dynamic meshing to join the 10 frames together for one simulation? I would also like to interpolate results in between each frame - I'm not sure if this is possible.
For dynamic meshing, I have seen people use UDFs, but I'm not sure how to generate a UDF from the 10 frames of data.
NOTE: I am working in ANSYS Fluent
Thanks in advance.
September 3, 2018 at 9:58 pm
Raef.Kobeissi
SubscriberCan you please upload a schematic to make a better understanding of your case.
Regards
September 3, 2018 at 11:26 pm
September 4, 2018 at 2:03 am
Keyur Kanade
Ansys EmployeeHi,
If you have 10 case files and 10 dat files then you may want to try EnSight. But I dont think EnSight or CFD Post is part of student version.
In Fluent, you can Append case and data files using Setting up domain --> Zones --> Append.
Keyur
September 4, 2018 at 3:45 pm
SubscriberKeyur,
CFD Post is in the Student version.
Peter -
September 5, 2018 at 2:53 am
Keyur Kanade
Ansys EmployeeThanks Peter!
Good to know.
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2630
2104
1329
1110
461
