January 17, 2018 at 3:58 pm
fardinkhalili
SubscriberHi,
I want to do a simulation for a bileaflet mechanical heart valve. Initially, the geometry has very small gaps like 0.05-0.1 mm in the hinges. The pulsatile fluid flow through the valve and leaflets rotate around their hinges (1DOF). During the backflow the leaflets closes the flow domain and prevent the backflow. The movement of the leaflets are not predefined and they move based on the pulsatile flow.
Questions:
1. Should I choose the dynamic mesh approach or overset mesh?
2. What should I do for the small gaps since the small flow with higher stresses inside the hinge (small gaps) are also important?
3. What criteria for the meshing should I consider if I want to have LES as turbulence models
Thanks.
February 7, 2018 at 4:45 pm
saadyw
SubscriberHi
could you attach a sketch for more understanding ?
February 8, 2018 at 3:02 pm
fardinkhalili
SubscriberI did simulation using 1-way coupling Fluent and transient structural.
My question is now:
This a mechanical heart valve simulation in which the leaflets rotate about 55 degrees around their hinges to fully close the flow domain.
I run the simulation from fully-open position for a while so that the flow gets stable and then the leaflets are allowed to rotate. I have improved the simulation using Dynamic mesh option (smoothing diffusion parameter 1 and 2, layering height ratio and default parameters, and remeshing local cell, face and region remeshing). Now the leaflets rotate up to the last angles and simulation diverges before the leaflets and valve close.
The skewness angle is less than 0.65 at the beginning but the mesh cells get compressed and stretched to get skenewss angle of 0.96.
February 8, 2018 at 6:02 pm
Vishal Ganore
Ansys EmployeeHi Fardin, you need to play around with re-meshing parameters and time step size (use smaller time step). Looks like your cells are not getting re meshed well when it exceeds max and min length scales. Also, in which region cells skewness is going beyond .96? Have you assigned any motion to leaflets?
February 8, 2018 at 6:24 pm
fardinkhalili
SubscriberHi Vishal,
The leaflets are moving (known rotation from transient structural coupled with Fluent) from 0 angle to 55 degree.
Yes, It seems that remeshing is not doing anything as you see the mesh is streched at the center and compressed between the leaflets. I am using Local Cell, Local Face, Region Face for remeshing methods, Sizing Function is NOT on. I set the Minimum and Maximum Length Scales from the Mesh Scale Info and set the maximum cell skewness and face skewness to 0.85 and size remeshing interval is 1.
The highest skewness angle is 0.7 before running and get higher than 0.96 in regions: 1. mostly between the leaflet tips, 2. leaflets and wall on both sides.
February 8, 2018 at 6:49 pm
Vishal Ganore
Ansys EmployeeHave you assigned any motion in transient structural? what is your motion equation? I wish to know the reason behind using transient structural. With using UDF in Fluent, you might get good control.
Do you have uniform mesh all over your fluid domain. If no then using mesh scale info on meshing parameters may not work. Please share your project file achieve. Let me investigate.
February 8, 2018 at 6:57 pm
fardinkhalili
SubscriberYes the motion is assigned to the leaflets in transient structural based on a table including time and rotation angle. The reason is just doing the 1-way coupling as an approach for this simulation. we have used dynamic mesh and overset mesh and similar problem occurs when the leaflets is closing.
I added body sizing and sphere of influence and increased the quality of the (smaller size) in the region around the leaflets. It means that from inlet to downstream of the leaflets have smaller mesh, and larger mesh elements for the rest of the flow domain (far downstream of the leaflets.
February 8, 2018 at 7:09 pm
Vishal Ganore
Ansys EmployeeI suggest you to separate dynamic mesh affected region near the leaflet from main flow region and generate uniform mesh for leaflet region. This will help solver to correctly predict maximum and minimum length scale in a select region for remeshing.
Is there any linear or non linear relation between time and rotation angle. If yes then define that equation through UDF in Fluent to cut down extra transient structural physics.
March 5, 2018 at 3:46 pm
saadyw
SubscriberHi Fardinkhalili
I except that you should use sliding mesh (not dynamic). This approach allows you to enclose the leaflets by interfaces and assign them to rotate with the desired angle according to a udf. see sliding mesh section in the fluent theory manual.
Regards
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2616
2096
1321
1108
461
