October 27, 2017 at 9:57 pm
ADITYA
SubscriberIn ansys 18.2, while I am running a 2d turbine simulation using 6 DOF under dynamic mesh module is it necessary to give moment of inertia (IXX,IYY and IZZ) in 6DOF properties. If it is, which moment of inertia (out of these three) I have to calculate for my simulation.
October 27, 2017 at 10:28 pm
Raef.Kobeissi
SubscriberHello ADIYTA
IXX, IYY and IZZ are indeed the mass moment of inertia. In a 2D object you can use the perpendicular theorem to calculate the 3 of values of IXX IYY and IZZ. IZ=IX + IY , if the object has rotational symmetry then you have the advantage of having IX = IY (XY is the plane of your rotating object) -
October 28, 2017 at 5:50 am
ADITYA
SubscriberThank you sir, Sir in one of your tutorial in you tube titled " CFD ANSYS Tutorial - Simulating Turbines using dynamic mesh and 6DOf | Fluent" you have taken moment of inertia in kg-m2 of 2d object in 6DOF properties . Is it 2 IXX only or something different. For 2d surface how moment of inertia can be in kg-m2.
At last Sir, Thanks for your quick reply.
ADITYA
October 28, 2017 at 9:18 am
Raef.Kobeissi
SubscriberHi ADIYTA The rotation would have been around the Z axis so that would be the IZZ -
October 28, 2017 at 6:49 pm
ADITYA
SubscriberSir, Thanks for your help in my project work.
Aditya
October 28, 2017 at 7:30 pm
Raef.Kobeissi
SubscriberYou’re most welcome ADITYA! -
November 14, 2017 at 4:32 pm
ADITYA
SubscriberSir, Sorry to disturb you again. Actually I am working on Darrieus type vertical axis wind turbine with three blades of NACA 0018 profile. After following the procedure you have adapted in your tutorial titled " CFD ANSYS Tutorial - Simulating Turbines using dynamic mesh and 6DOf | Fluent" the turbine is not at all rotating. Here i have two different zones one for stator and other for rotor, the rotor is equipped with three blades of the turbine at 120 degree angles apart. Sir where is the problem. Wating for your reply.
Aditya
November 15, 2017 at 11:18 am
Raef.Kobeissi
SubscriberHello is it 3D? Can you post some pictures of your setup please.
Regards -
November 17, 2017 at 6:11 pm
November 24, 2017 at 1:04 pm
ADITYA
SubscriberSir waiting for your reply. Sir please retrieve me out from this problem.I have followed all the steps of your tutorial but still its not rotating.
With Regards
ADITYA
December 4, 2017 at 7:08 pm
sergiks
SubscriberSir, returning to "CFD ANSYS Tutorial - Simulating Turbines using dynamic mesh and 6DOf | Fluent", could you tell please, how we can calculate angular velocity of turbine in this case?
December 4, 2017 at 8:15 pm
Raef.Kobeissi
SubscriberIn the dynamic mesh properties window you can see the angular velocity of the moving object and I believe you can write a data file for each time step.
2610
2088
1319
1108
459
