December 7, 2019 at 4:31 pm
tomdillon97
SubscriberHi,
I want to run a coupled simulation of crack growth that arises from fluid-solid interface. I am unsure of how to setup my dynamic mesh so that as the crack grows in a structural simulation, a fluid mesh fills the void (thus creating a larger surface area over which the fluid pressure acts). Is this possible using ANSYS (mechanical + fluent) coupled functionalities? I know how to define a critical fracture toughness, how to define interface delamination, and how to create a coupled fluid-solid interface in ansys. Are there any particular settings in I should be aware of when defining a dynamic mesh that grows from an initial 0 thickness crack to a fluid domain?
Thanks!
Tom
December 9, 2019 at 4:50 pm
Ansys EmployeeYou'll need to start the model off with a small crack, and note that mesh requirements from Fluent are going to be high.
December 9, 2019 at 6:13 pm
tomdillon97
SubscriberThank you,
So I can simply define the crack as as a fluid solid interface, and as delamination progresses, the mesh will grow from the 0 thickness surface utilising dynamic meshing?
December 10, 2019 at 3:22 pm
Ansys EmployeeYou'll need a finite thickness to start with: you can't change the topology with moving mesh.
February 29, 2020 at 4:38 am
tomdillon97
Hi rwoolhou,
to follow up on this, I am using VCCT and an FSI in ansys. My fluid + solid geometry are as follows.
I have a small initial crack as above. Will I see the FSI grow if I remeshing is used once delamination begins (at the critical G1 value)?
Many thanks
Tom
5386
3375
2471
1310
1022
