Dynamic Meshing/Layering
    • MichaelJunker
      Good morning,
      I got a problem with a transient Simulation. It seems like a simple dynamic mesh problem, but whatever I try it won't work.
      The geometry is a cylinder with one In- and four Outlets. The basic idea is that the fluid that is inside the cylinder will be pushed out and the geometry will be shrinking. I chose the Layering dynamic mesh method. I watched a lot of tutorials on youtube and they didn't help me with this problem. Am I missing something easy or is this actually a more complex simulation?
      Thanks for your help,
      Michael
    • Vishal Ganore
      Are you running 3D or 2D?
    • MichaelJunker
      It is a 3d simulation
    • Vishal Ganore
      Ok. It should be very straightforward. Let me find out the getting started tutorial for you. Hold on!
    • Vishal Ganore
      Can you provide bit more detail about your model? how are you defining shrinking geometry? will there be a fluid flow from inlet to outlet?
    • MichaelJunker
      Excuse me for answering so late, was a busy weekend. My idea was that a pressure inlet would push the fluid out of the zone, thanks to the dynamic mesh. There shouldn't be a fluid, just the pressure on the surface.
    • Raef.Kobeissi
      Hi Michael I have a 2D tutorial similar to your case which can be applied on 3D case
    • MichaelJunker
      Thank you for the help. I found the mistakes in my setup.
Viewing 7 reply threads
