April 26, 2023 at 12:56 pm
Chinmaya Kumar Patra
SubscriberI have a rectangular channel with single phase adabatic flow in which i am calculating the transient variation of dynamic pressure (area wehighted avg) and velocity (area wehighted avg) at different locations (0 mm-inlet , 0.5 mm, 1.5 mm, 2.5mm, 3.5 mm and 4.5mm-outlet) along the length of channel as shown in plots below. It can be seen from velocity plot, the oulet velocity is less as compared velocity at inlet but the dynamic pressure trend is opposite, how is it possible? as the dynamic pressure is a function velocity and density (remians constant through the simualtion).
In addtion the velocity trends for diferent locations are not matching with the dynamics pressure trend. -
April 27, 2023 at 8:52 am
Ansys EmployeeThe clue is "area weighted average". Have a look at the definitions, and then look at mass weighted.
April 27, 2023 at 12:01 pm
SubscriberBut for calculating both the dynamic pressure and velocity i have used area weighted average. So should i try out both these parameters with mass weighted average.
April 27, 2023 at 1:25 pm
Ansys EmployeeHave a look at the options to see which is most suitable.
- What is the difference between internal and external flows?
- Why is it much easier to roll a log than drag a wood cube with the same mass?
- The level of water inside the straw was higher than the level of water in the beaker
- How do you define specific gravity? What is its significance???
- Why does the total sum of forces acting on a system always have to be equal to zero?
- What is the surface tension of a fluid?
- Cell Counting?
- Explain Bernoulli’s principle
- How to gain research experience?
- Whats the difference between sensible heat and latent heat?
5290
3311
2471
