February 2, 2023 at 12:06 pm
Patrick Straker
Subscriber1.I dont really understand the difference between thees moduls can someone pls explain to me? all 3 of them are used for simulation like drop test?
2. as a Student i can install and ues LS-dyna as a seperet Programm but not as an Workbench tool ? and are restrictet to use Explicet dynamics is that correkt?
3. if so i find many tutorials on LS-Dyna but very few on the Explicet dynamics tool can some one help me find lerning material for that? -
February 3, 2023 at 2:32 am
SubscriberAll three programs can simulate a drop test. Transient Structural requires contact to be defined prior to running the analysis. Explicit Dynamics automatically detects body to body contact when the solution begins.
Explicit Dynamics and LS-DYNA both use an explicit solver, which means it takes very small time steps so that dynamic equilibrium is always maintained. Transient Structural uses an implicit solver, which means it can take large time steps but it must converge on the dynamic equilibrium at each time step and may fail to converge.
Transient Structural and Explicit Dynamics are more tightly integrated to run inside Mechanical Workbench. LS-DYNA is less well integrated into Mechanical Workbench and uses stand alone LS-Prepost and LS-Run programs.
Here is a list of YouTube videos on Explicit Dynamics: https://www.youtube.com/results?search_query=ansys+explicit+dynamics+tutorial
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
5162
3251
2443
