December 27, 2022 at 5:45 pm
iqnlo
SubscriberHi All
I am simulating fibre mode now and am a little bit confused about the difference between "E intensity" and "Ex, Ey, Ez."
In fibre data sheet, we always say that the Mode Field Diameter is how many um. MFD is typically defined as the radial position where intensity falls to e-2 of the peak intensity. So MFD definition sounds like the definition of "effective mode area" in Lumerical.
However, could someone please explain the difference between the difference of each E component? And which E component is used for calculating the MFD (effective area)?
Thank you very much!
December 27, 2022 at 9:44 pm
Guilin Sun
- Error on Lumerical device
2688
2138
1355
1136
462
