June 7, 2023 at 7:33 pm
Simon-Olivier
SubscriberI am not able to impose an ECC in function of the GAP (using TABLE) in my Structural-Thermoelectric analysis (using surface174, KEYOPT(1)=3 ).
I have no problem with TCC in function of GAP (using TABLE).
The default analysis seems to impose a very low ECC value when there is a gap (but I am not able to know this ECC value...).
I was wondering if someone can confirm to me that it is impossible in this analysis type to have an ECC function GAP. Also what is the ECC default value when there is a gap for a Structural-Thermoelectric analysis?
Thank you very much for your help!
June 8, 2023 at 1:45 pm
Erik Kostson
Ansys EmployeeHi
See the contact technology guide in the help manual and :
7.2. Modeling Electric Contact and 7.2.1
3.9. Set the Real Constants and Element KEYOPTS
All the best
Erik
June 8, 2023 at 5:09 pm
Dave Looman
Ansys EmployeeBy default ECC for an open gap would be zero. When you defined ECC as a function of Gap did you use negative values as described below in Section 3.9.1.2 of the Contact Technology Guide?
Geometric contact gap/penetration (GAP):
Numerical offsets are not included.
Specify positive index values for penetration, negative index values for an open gap.
4476
2957
1433
1322
