September 24, 2023 at 8:04 am
Vedant Sane
SubscriberHello,
I am trying to extract ECE model from Maxwell. I already extracted the model as well as I compared its results with FEA results. However, the results are not matching. I used the following settings for PMSM 6 pole motor and I used 1 single pole FEA.
ECE3_Model:
CurrentSweeps: (60A, 10)
PhAngIntervals: 2
ECER_Model:
RotAngleMax: 10 deg (InElecDeg - Unchecked)
RotAngIntervals: 10
Poles: 6
Slots: 54
September 26, 2023 at 6:19 pm
HDLI
Ansys EmployeeHello Vedant,
Could you attach the pictures again? because we cannot see them.
Could you check current? Thanks.
HDLI
- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3153
1688
1478
