Materials
Materials
EcoDesign project: Hand paddles
    • János Bánk
      Dear Ansys Team, hello everyone,
      unfortunately, there was not enough time for our question on Tuesday's Ansys Webinar at TU Berlin. We have chosen the product hand paddles for swimming for our project. We have specified that it is a "panel in bending" and that the following conditions must be met:
      - Physical properties: a minimal density
      - Mechanical properties: a maximal Young's modulus
      - Durability aspects: resistant against chlorinated and salt water
      For the implementation, we specified in EduPack under physical properties a maximum density of 998 kg/m³ (so that the object also floats), and under durability we specified excellent for water (fresh) and water (salt) and acceptable/excellent for weak acid/alkali (refers to the chlorinated water). Optionally, we have entered good/excellent for UV radiation (for outdoor use).
      Our question now refers to the result we get for the environmental and economic optimization, because in both cases besides polypropylene and polyethylene (which are standard) - depending on the exact settings, e.g. durability with less information – we unfortunately get materials that are completely unsuitable for hand paddles (foam, brick).
      Do you have any idea why this is the case, or how we might have to adjust our conditions to get a larger material selection? We thought about processability (while reducing other constraints), but we could only guess. Giving constraints for (tensile) strength at least eliminated foams.
      Do you think that overall a "strength limited" approach might be more appropriate?
      Many thanks in advance!
      With best regards
      Carla and János
    • Elisabeth Huelse
      Dear Carla and János,
      Thank you for your questions and sharing your ideas and interesting project with us.
      In general, I would say you are on a good track to tackle your problem. Here are a few comments:
      • It does make sense to look for materials with a low density (you don’t want the paddle to drag you down while paddling). However, think about the fact, when the material is too light and the swimmer has to use a lot of energy to push it into the water to hold against it’s high buoyancy. So I suggest finding a good compromise.
        Since you already mentioned that most hand paddles are made out of PP or PE you can use those as a reference point. You can also consider general paddle material such as carbon and glass fibre reinforced plastics.
      • You have also done some good thinking about the additional constraints, such as durability. Here I would also refer back to your reference materials. I noticed that setting durability regarding UV radiation at excellent also results into even loosing your reference materials. Go ahead and explore what their durability regarding UV radiation is. Keep in mind that there are good reasons for specific materials to be used most commonly for certain products; i. e. PE might only have “fair” durability regarding UV radiation, but the paddle might be coated for extra protection. Plus the paddle is not constantly exposed to sunlight (i.e. when stored somewhere and not in use), so it does not necessarily have to have excellent durability.
      • I would keep the stiffness-limited design as you want to have low flexibility of the paddle, so that the energy transfer is most efficient (muscle energy put into paddle is transferred into propulsion)
      What have you formalized as your goal for this material selection project? What are you trying to achieve by finding an alternative material to the one usually used? So WHY are you looking for a different material?
      I.e. Do you want it to be more environmentally friendly? Do you want it to be cheaper?
      Try to find constraints around those questions to narrow down your choices and to achieve what you are looking for. (e.g. restrict to only recyclable materials)
      By the way, it was not wrong to start with those constraints, such as UV radiation. This is all part of the process. Sanity checking the results, comparing with the reference material, finding reasons for results that seem to be unrealistic, and repeating the process with adjusted conditions to achieve your goals.
      The more constraints are added, the more difficult is becomes to find an optimal pool of candidates.
      Hope this helps. Good luck with your project!
      Elisabeth
    • János Bánk
      Dear Elisabeth,
      thank you so much for your detailed answer! And sorry for not replying earlier. We used your advice right away, and it helped a lot! We then got lost in other uni stuff...
      Maybe see you next Tuesday!
      Best,
      János
