Eddy-Dissipation and crosslinking
    • Patrickodon
      Hi all,
      Does the Eddy-Dissipation setting in Species Model -> Turbulence-Chemistry Interaction -> Eddy-Dissipation allow for crosslinking in mixing, or does that have to be programmed in via a UDF?
      Only in the sense that you create a new material during the reaction that can have different properties. Which then leads back to the previous discussion on how you actually set the material properties....
