September 4, 2018 at 8:52 pm
cehangir
SubscriberHi
I am working on coal combustion. I have already simulated a model based on Eddy dissipation/Finite rate (ED/FR) for coal combustion.
Now, I want to compare the eddy dissipation concept (EDC) using detailed chemistry. Can someone provide me any guideline how to start off with EDC, I am not able to find any tutorials on EDC.
September 4, 2018 at 11:59 pm
klu
Ansys EmployeeHi
Please take a look at a demo video below.
September 5, 2018 at 2:15 pm
cehangir
SubscriberThanks for the demo.
However, I am trying to find a tutorial/demo/example for the EDC (eddy dissipation concept) that can provide me how to include the detailed chemistry.
September 5, 2018 at 5:15 pm
DrAmine
Ansys EmployeeThere is no standard official EDC tutorial which can be shared. On the ANSYS Learning Hub there are some actual dedicated workshops. Here we need a training subscription.
September 6, 2018 at 9:43 pm
cehangir
SubscriberCan you provide me some steps how I can initialize EDC.
From what I have gathered from different sources, I have understood the following:
1. in order to have a good initial guess, I should run the simulation using ED/FR till it converges.
2. Change the TCI from ED/FR to EDC.
3. Import the chemkin mechanism.
4. Set ISAT parameters
I will really appreacite if I can get any advice on it.
September 7, 2018 at 2:48 pm
Ansys EmployeeIt's not an area that I'm too familiar with, but please try the steps you've mentioned and let the community know how you get on.
September 7, 2018 at 3:24 pm
cehangir
Subscriberthanks for the input. I will try that and will update on the thread.
In the meantime, I will really appreciate if there is any suggestions from student community.
September 7, 2018 at 6:29 pm
DrAmine
Ansys EmployeeYes the solution strategy is fine. Just you might elaborate a bit on URFS and be patient.
September 7, 2018 at 7:25 pm
cehangir
SubscriberThank you for the motivation.
Since I am using coal as a fuel, EDM considers volatile to be a Global reaction (CxHyOz). When I set the model for EDC, how do I divide the volatiles released to its constituent products (CH4, CmHn, H2).
September 8, 2018 at 7:36 am
DrAmine
Ansys EmployeeStart from more sophisticated Model with TCI allowing for intIntermediate species -
October 7, 2018 at 7:24 pm
DrAmine
Ansys EmployeeIs your problem solved? If yes please mark this topic as solved. If not please create a new topic with fresh input.
October 8, 2018 at 11:57 am
2524
2066
1279
1096
457
