Edit geometry in Ansys 2021 R1?
    • amando.gallardo
      Hello! I have imported a geometry into a static module, however there is no option to edit it. Do you know why?
      Thanks for your feedback!
    • Saumadeep
      Hi @aagallardo
      You will first need to import the geometry. If the geometry import was successful, you will see a "tick mark" symbol appear on the Geometry tab.
      Once the geometry gets imported, we can right-click on geometry and select "Edit Geometry in SpaceClaim" or "Edit Geometry in DesignModeler"
      Also, make sure you have the license for SpaceClaim and DesignModeler.
      Regards, Saumadeep
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
    • amando.gallardo
      Yeah, I put a wrong picture of the issue. I already had the geometry loaded on the module and even so, the edit option was not available.
      At the end the problem was more related with the CAD configuration inside Ansys:
      Thanks a lot for your help! :D
    • m_youssef91
      How can I edit a geometry drawing on spaceclaim after already converting it to Solid?
      • bhagwantP
        Hello m_youssef91,
        you can take up basic tutorials available for geomtery editing in spaceclaim for better clarity.
        Just citing few sample links:
        Thanks
Viewing 3 reply threads
