January 23, 2023 at 8:00 pm
G12070854
SubscriberHi, i´d a problem when i hitting right-click on mouse for the opcion "Edit sketch" for a analisys on Spaceclaim, because i try to delete the surface to copy the lines in onthers planes (1st image), and the 2th image is how the tutorial indicates the step. Someone could tell me how to do it?
my ansys is 2022 R2 student version
January 24, 2023 at 5:57 am
Keyur Kanade
Ansys EmployeeYou can select the edges to copy. Then use ctrl + c and ctrl + v to paste those edges.
Please go through help manual for more details
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2138
1349
1136
462
