TAGGED: 3d-geomertry, geometry, geometry-editor, spaceclaim
February 19, 2022 at 3:39 am
m_youssef91
SubscriberCan I edit a sketch in the Spaceclaim after converting it to solid? If yes, could you please tell me how?
February 19, 2022 at 1:45 pmpeteroznewman
SubscriberThere is no sketch after it becomes a solid. You can pull the face of the solid to change the shape using the Pull tool.
February 20, 2022 at 10:21 pmm_youssef91
SubscriberSo if I want to change a radius or any dimension on the model I should redraw it from the beginning?
February 20, 2022 at 10:51 pmpeteroznewman
SubscriberIn SpaceClaim, on the Design tab, there is a button on the ribbon called Pull. Click that (or type P on the keyboard), then click on the cylindrical face. An arrow and a dimension will pop-up. Drag on the arrow or type in a new value for the dimension.
February 20, 2022 at 11:29 pmm_youssef91
SubscriberThank you very much, I did it
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3862
2639
1859
1254
600
