Editing field in the “imported trace worksheet” under the “filled” column
    • agupta8
      As we import the PCB tracks in ansys mechanical, the worksheet provides different properties that can be modified as required. The table includes one of such property with column heading as "filled". There is a checkbox for each via/pad row entry in that column. Alongside of that checkbox, there is an editing field also in the same column. One can write any number into that (large or small). What is its purpose?
    • Rahul Kumbhar
      I think this field is for checking/unchecking purpose only. Although you can insert some text there but it is not useful for anything.
