Editing session file to generate points around a circular wall and export data
    • Chris Ryan
      I'm trying to extract data from my model at each point around a circular wall to generate a data vs angle plot. I've been reading previous post about this issue and have found that session files seem to be the best way to achieve this. However, I do not understand how the session files have been edited to generate all the points and extract the data at each point.
      Can I please get an explanation of how to edit session files and create these loops. Or is there an easier way to plot this data without the use of session files?
    • Essence
      You can try using the "Plot" option in the Fluent where you need to specify the plane (surface) from where you need the points to plot.
