August 20, 2019 at 6:59 pm
pmt22
SubscriberI am using K-omega SST model with heat transfer for pipe flow. I ran the simulation for y-plus value less than 1 and got the convergence now I am trying to get grid independency for my case but as I am refining the mesh y-plus value also decreases and I am getting a different result each time. so my question is how to approach grid independency for this case and what should be the lower limit of y-plus I should try.
regards
August 21, 2019 at 6:26 am
DrAmine
Ansys EmployeeWhat do you mean by different results? How are you doing the refinement? Is it steady/unsteady?
August 21, 2019 at 10:25 am
pmt22
Subscriberit is a steady axisymmetric flow. I am refining by decreasing the size of the element in radial and axial direction. my quantity of interest is wall temperature and there is a peak in wall temperature but as I am refining the mesh the peak value decrease rest profile remain the same. so my question is this normal and what is the minimum limit of y-plus I should go or whether for grid independency I should keep the y-plus constant and refine the bulk?
regards
pmt22
August 21, 2019 at 12:36 pm
DrAmine
Ansys EmployeeWhat happens if you keep increasing the mesh density? I do not want to comment in detailed fashion when it comes to refining a mesh using a RANS model.
August 21, 2019 at 4:00 pm
pmt22
SubscriberThanks for your reply. The wall temperature has a peak value that kept on decreasing when I increase the mesh density. can you name any source where I can look for this topic??
Regards
pmt22
August 21, 2019 at 4:03 pm
DrAmine
Ansys EmployeeDo you have data to compare with? What happens if you continue increasing mesh density? You look after Richardson extrapolation for grid independency study.
2656
2120
1347
1118
461
