April 16, 2022 at 4:30 am
rajatkumar.sinha
SubscriberHey, I am trying to find the effective index of a mode inside the waveguide which has a grating on top. The waveguide looks something like
April 25, 2022 at 11:25 pmKyle
The FDE solver in MODE calculates waveguide modes assuming that the refractive index cross-section is constant along the direction of propagation, for straight, bent and helical waveguides. If there is a grating this means the index cross-section is changing, so FDE can't be used. For this reason, typically FDTD or EME would be used for simulations with gratings. We have some examples of grating and photonic crystal simulations available in our Application gallery here that might be helpful for you: https://support.lumerical.com/hc/en-us#app-anchor
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
8786
4658
3151
1678
1468
